mig liner wear
发表于 2021-9-1 01:00:11 | 显示全部楼层 |阅读模式
Does your mig have a burn back or other feed related problem? A worn liner is suspect in lots of mig malfunctions. The place where the most wear occures in the liner is where it takes its first 90 degree bend. About 8 inches out where it heads for the floor, right? A quick fix. Tie or otherwise attach a straight object,[broom handle, angle iron, ect.] to your machine and to the mig gun lead. The object being to move the bend of the liner a little further out on lead. This will get you thru the day and sometimes thru the next couple of months. If your welder lead is close enough to the floor a chair or a box placed under the lead to hold it straight will do the job.
Reply:uh did I miss something   oh well   IF it Catches...Let it Burn
Reply:Looks like just posting a general tip in case someone does experience liner failure.  Though, I never have.  Good idea, though.
Reply:Well yeah I think it is.  I just was worried I somehow missed where the other posts were.   Good tip thoghIF it Catches...Let it Burn
GMT+8, 2025-12-20 02:54 , Processed in 0.093824 second(s), 18 queries .
