Starting off
发表于 2021-9-1 01:00:10 | 显示全部楼层 |阅读模式
I have some questions on setting up my HF-250 tig welder. I just bought it used. I understand I should use DC negative to weld autobody panels. Is anybody here familiar with this welder?
Reply:What are your peramteters.need gas type..assuming argon.  Need tungsten dia.need thickness of materialneed wire you plan to use.  yes I know its GTAW but its still wire, just cut length.  if you know the thickness, just dial in and add an amp for every .001   for instance.   1/8" is .125" therefore 125 amps.    1/16" = .0625"  62 amps.  Hope this helps.IF it Catches...Let it Burn
GMT+8, 2025-12-20 02:56 , Processed in 0.070685 second(s), 18 queries .
