Glasses for Plasma cutter
发表于 2021-9-1 01:00:06 | 显示全部楼层 |阅读模式
Ive been using a ESAB 875 plasma cutter and the local welding shop sold me shade 5 glasses. When I cut for a while I see black spots for a while. Are shade 5 glasses dark enough for a 60 amp plasma cutter ?
Reply:Depends.  They are probably already a shade 14 to UV, like most welding helmets, so only the visible spectrum is a shade 5.  It's really all about what comfortable for you.  I use a shade 5 myself for plasma and O/A.
Reply:#5 safety glasses here for plasma.   I've gotten into the habit though of blinking as the cut exits the material to avoid getting flashed.There are no small projects
GMT+8, 2025-12-20 02:53 , Processed in 0.105498 second(s), 18 queries .
