Brass and copper
发表于 2021-9-1 01:00:01 | 显示全部楼层 |阅读模式
I've got a couple projects that i want to do in brass and one in copper. Now the question is can i use a MIG and if so what gas do I use?
Reply:100% argon yes you can mig brass copper im not shure ofLast edited by chopper5; 05-19-2006 at 08:21 PM.ChuckASME Pressure Vessel welder
Reply:shouldn t copper be sweated or soldered? because it is soft low melting point
Reply:Originally Posted by prop-doctorshouldn t copper be sweated or soldered? because it is soft low melting point
Reply:i've tigged "oxygen free" copper in the past...no fun at all  but it can be done  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:also be stick welded.We have 4 or 5 products for this application.
Reply:why not braze it up?
Reply:I've silver brazed tons of copper and it works great.  I've also tig welded like 1/8 sheet without too much problem.  The thing is that copper absorbs oxygen when it is hot and when you are trying to weld thicker stuff the heat will get ahead of your weld and gets contaminated.  Helium might let you weld quicker and stay ahead of the heat.
Reply:Thanks for the info. Thats what I needed to know.i'll put up some pics as soon as i get done.
Reply:I just welded up some tantalum bonded to copper for the past 3 days now thats a nightmare  used helium/argon mix and preheated to 550+ and back purged the heeck out of the tantalum side. I took some pics this morning. Thats got to be one heck of an explosion to get them two materials to stick together
Reply:I've tigged both brass and copper. Not much fun, but it can be done with great results i might add. Siver solder might be the way to go though.
GMT+8, 2025-12-20 02:54 , Processed in 0.098772 second(s), 18 queries .
