查看: 13|回复: 0
Titanium natural color?
发表于 2021-9-1 00:59:58 | 显示全部楼层 |阅读模式
What is the normal / natural color of titanium?  Because there are lots of electric hair shavers out there that have titanium blades.  But when I look at the blades they are gold in color.  But I always though titanium was gray.  So I got confused on what color it actually is.
Reply:It's gray.
Reply:It's gray. The gold is most likely a cadmium plating. Don't ask me why you would want to plate titanium....cuz I don't know the answer.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:How much stronger is titanium then mild steel or like AR 500 hardox?
Reply:The gold is Titanium Nitride, same as for your drill bits.  I think Zirconium nitride gives better hardness, it's a little more gray but still has some gold tint to it.
Reply:So is this titanium nitrate as strong as just pure titanium?  Do you know what titanium alloy is the strongest?  But just 100% pure titanium is gray right?
Reply:Don't confuse hardness and strength.Titanium is fairly strong, especially for its light weight; it makes good knife handles and aircraft parts.Titanium Nitride is very hard and makes a good coating for cutting edges and such.
Reply:I know the difference between hardness and strength.  You say titanium is fairly strong.  I though titanium is the strongest element off the periodic table known to man.
Reply:From my r/c hobby, I was under the impression that Ti's advantage is that it's close to the strength of steel, with weight closer to Aluminum. I could be wrong though.
Reply:6Al4Vmay be the strongest. I don't know for sure. Lot of aircraft and racing parts use this alloy.............. Approx.2/3 the weight of steel....... One of the most corrosive resistant metals.............. Drill bits are not made of titanium.They are steel or carbide.Coated with Ti-Nitride which I think is a vapor deposition process. Ti-N is a harder material than the substrate it is placed upon and gives longer tool wear provided feeds and speeds are correct................. Most if not all Ti. alloys can be welded,turns beautiful colors when welded or heated. Can also be anodized to beautiful colors.
Reply:Titanium may be the strongest element, but steels and such can be stronger (steel is not an element as it is a mixture of iron, carbon, and other elements).  Osmium is the hardest element.  Titanium nitride may not be a metal just as iron oxide (rust) is not a metal.Last edited by 76GMC1500; 06-07-2006 at 01:06 PM.
Reply:Titanium has high heat properties, as well as anticrosion.  You can imagine how important high heat properties would be to soemthing like a hair clipper or a drill bit.   When metals get hot, its all respective, they tend to loose strengths.  So they get dull.   If you have a metal that will retain properties at higher temps, you have a longer life material.IF it Catches...Let it Burn
Reply:Originally Posted by alan watersMost if not all Ti. alloys can be welded,turns beautiful colors when welded or heated. Can also be anodized to beautiful colors.
Reply:Originally Posted by JeffBFrom my r/c hobby, I was under the impression that Ti's advantage is that it's close to the strength of steel, with weight closer to Aluminum. I could be wrong though.
Reply:It is not MUCH stronger than steel.  High strength alloys of titanium net 150ksi, similar to low grade chrome moly steel.  4340 chro mo has a tensile strength of upwards of 285 ksi, nearly twice as strong.  Some tool alloys are like 450+ksi.
Reply:So basically the rumor that titanium alloys are the ultimate product for strength is just a load of bs compared to other high strength steels?
Reply:Originally Posted by SPL TechSo basically the rumor that titanium alloys are the ultimate product for strength is just a load of bs compared to other high strength steels?
Reply:Titanium     is     very strong , FOR ITS  WEIGHT . its about 2/3 the weight of steel. That's why some race motors (engines) like racing Porches  used them, (factory racers ) . dragsters don't use them ,because they are about 1/3rd  heavier that aluminum rods and they replace the aluminum rods as often as necessary, no matter the cost. after all , it's sponsors money , not theirs .GNM 109 mentioned heat resistance . he is correct.  I saw an f 104 land at Hamilton air force base once, he pulled up to the transit alert , and a tug came rightaway, & pulled it into airo-repair. I went to see what was wrong . the wings were NO longer shiny , but dull and crispy . it seems it could go way faster than the "official listed speeds" , the pilot burned the wings with speed ! had to re skin it
GMT+8, 2025-12-20 04:34 , Processed in 0.100012 second(s), 18 queries .
