what filler
发表于 2021-9-1 00:59:54 | 显示全部楼层 |阅读模式
I am building a boat of 5083 alloy plate. I have been given conflicting information as to what filler wire to use, is 5356 suitable, or do i need to use 5183?Thanks in advanceVIN
Reply:Both should weld that alloy.  5183 will yield greater strength, while 5356 should have better elongation properties.  I don't build boats and can't comment on which is better for you.
Reply:if your sending the parts out for annodizing then 5356 is what you want......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:If you go with the weld with better elongation, you will have less of a problem with cracks down the road.  Boat hulls twist and flex and if any weld holds more rigidly than the others, the forces concentrate on it and it will crack.
Reply:Originally Posted by daedongI am building a boat of 5083 alloy plate. I have been given conflicting information as to what filler wire to use, is 5356 suitable, or do i need to use 5183?Thanks in advanceVIN
GMT+8, 2025-12-20 03:49 , Processed in 0.109384 second(s), 18 queries .
