Miller Blue Star 145
发表于 2021-9-1 00:59:53 | 显示全部楼层 |阅读模式
how thick material (normal mild steel) can you weld with a 145 amp DC stick machine?145 A at 25 V, 20% duty cycle100 A at 25 V, 60% duty cycle
Reply:The general rule is .001 per amp.  Stick may go a little more so i would guess 3/16 for an expirienced welder.  That's single pass.  for multiple passes there is no limit if you have enough time.  LOLDennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Originally Posted by Tailshaft56The general rule is .001 per amp.  Stick may go a little more so i would guess 3/16 for an expirienced welder.  That's single pass.  for multiple passes there is no limit if you have enough time.  LOL
GMT+8, 2025-12-20 03:47 , Processed in 0.068480 second(s), 18 queries .
