L tec migmaster 250 questions
发表于 2021-9-1 00:59:49 | 显示全部楼层 |阅读模式
I have just purchased a migmaster 250 and would like toget aluminium set up for it. Does the esab 250 accessories fit it? If not were could I get U rollers, teflon liner,guides for it? How about a spool gun? Also will a snap on spool gun match up to it or would anybody make an adapter? Any help would be greatly appreciated Thanks,Russ
Reply:I have a Linde 225, and have been able to get all my conumables threw airgas or http://www.stoodyind.com/write the tech at ESAB, they were pretty help full for me on some of my questions and getting me the factory book.you may even get lucky by digging threw the ESAB page in the tech info and find the info you need. on my linde the cover plate calls for a ST-23 spool gun.
Reply:http://www.weldingmart.com/Qstore/p001933.htmThis is pretty much your welder (for info only, not an endorsement of the site).Canyoncritter is right about the direct connect spool gun, but there are probably lots that will work with a bit of adapting.BTW, you got a really good price on that welder.  Although I didn't bid, I was watching...I don't live far from there.  Good luck and happy welding.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Thanks for the input, so far I have found out that they make an adapter for the prince xl gun and the standard gun is a st 23a
GMT+8, 2025-12-20 03:46 , Processed in 0.070255 second(s), 18 queries .
