nitrogen tank
发表于 2021-9-1 00:59:47 | 显示全部楼层 |阅读模式
hey guys not sure if any one will konw this but its worth a shot i was wondering if regulator for MIG gas will work on a nitrogen tank ??
Reply:my argon regulator doesn't fit my nitrogen tank.  Similar size but the threads are different.My angle grinder is my best friend!
Reply:I don't use nitrogen, but when I was searching for regulators recently on ebay, I noticed nitrogen was always listed separately...you know, some are argon/co2/helium and whatnot, but never did I see a nitrogen in there with the other gases, only by itself.  They both use 580 connectors, though.  Check these two out just for comparison.http://cgi.ebay.com/ARGON-REGULATOR-...QQcmdZViewItemhttp://cgi.ebay.com/Uniweld-Turbotor...QQcmdZViewItemIt MAY hook up (I am not sure), but there might be very large discrepencies in the measured flow and actual flow, because of the differences in the gases.Last edited by smithboy; 07-15-2006 at 10:01 AM.Smithboy...if it ain't broke, you ain't tryin'.
Reply:cool thanks for the help guysdo you guys know where to get it besides ebay ?  like an online store?? i searched on google all i am getting is for nitrogen for beer and stuff is ??Last edited by kickz; 07-17-2006 at 12:24 PM.
Reply:Western Enterprises manufactures gas regulator/bottle nipples, etc.http://www.westernenterprises.com/
Reply:We use an argon gauge on the nitrogen all the time when pruging S/S, never had a problem.StephenI'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
GMT+8, 2025-12-20 03:48 , Processed in 0.087464 second(s), 18 queries .
