Newbie with Oxy Fuel Question
发表于 2021-9-1 00:59:46 | 显示全部楼层 |阅读模式
Just picked up an Oxy Fuel Victor welding set.  I also have an Arc welder.My question is can I weld (braze) on an angle or does it have to be a flat surface?  Also any good books anyone recommends for me to learn oxy fuel welding?Thanks.
Reply:You can use oxyfuel in all positions, welding is a little easier out of position than brazing, but not much. You can weld only with acetylene, but you can braze and silver solder with propane, mapp or natural gas.bob creely
Reply:You can weld with oxy-MAPP.
GMT+8, 2025-12-20 03:46 , Processed in 0.093684 second(s), 18 queries .
