Update
发表于 2021-9-1 00:59:46 | 显示全部楼层 |阅读模式
Ok. I got some info back from the unions. Basically I'm screwed right now. I have to pass two welding tests before i am considered to actually become part of the apprenticeship program. So it's back to school for me until I can pass the test. Yikes!      ~ CandiObstacles are those frightful things you see when you take your eyes off your goal.- Henry Ford 1863-1947
Reply:don't worry you might find out that school is were you want to be anyway. And schools a good place to get the basics down
Reply:yes  you can learn at your own speed in school.  and not have to worry about the bosses deadline. it's tuff to start out. the noobie always get the  short end of the stick.. take your time candi and it will work out
Reply:Look on the bright side, that's not screwed.  You were looking for direction and now you have it.  Take some classes first.Smithboy...if it ain't broke, you ain't tryin'.
Reply:yea. i still have time to enroll for the fall at my local community college.  I got some welding equopment of my own. a friend of a friend welds professionally and he "hooked a sista up" so he's going to be teaching me athing or two as i'm going through school!  Thanks for all the support guys!~ CandiObstacles are those frightful things you see when you take your eyes off your goal.- Henry Ford 1863-1947
Reply:Yup, I agree. You got the direction you needed. Patience grasshopper. It will happen. Go to school and learn and it will all fall into place when the time is right. Practice with your toys and listen to the boards. I wish these things existed when I was first starting out. Things may have been different on many fronts.
Reply:yea.. the forum helps out a lot.. i didn't think there were that many people out there that cared. I'm happy!~ CandiObstacles are those frightful things you see when you take your eyes off your goal.- Henry Ford 1863-1947
GMT+8, 2025-12-20 03:47 , Processed in 0.151287 second(s), 18 queries .
