New to welding need info/help
发表于 2021-9-1 00:59:40 | 显示全部楼层 |阅读模式
I am trying to learn how to weld on my own not doing very well i must admit i am using a AC100 115,60HZ,20amp rated out put 230 volts arc welder. trying to fabricate snowplow extentions steel being used is 1/8 for moldboard and 7/16 fro the ribs what is the best rods to be using or is my choice welding equipment not a good one to try and learn on. looking forward for your input .Last edited by plow north; 08-07-2006 at 12:15 PM.
GMT+8, 2025-12-20 04:00 , Processed in 0.092040 second(s), 18 queries .
