Please Critique my welds PART 2:
发表于 2021-9-1 00:59:39 | 显示全部楼层 |阅读模式
Well a little more practice and a little more trial and error have led me to now.Specs:10 ga steelVoltage: DWire Speed: 2 3/4 - 3Welder: Lincoln 135Now my welds:[IMG][/IMG]
Reply:Arr forgot to list the wire.Wire: .030 Fluxcore (using the stuff till I have no more of it)
Reply:well for fluxcore its not that bad..good penetration..spatter dont seem too bad...keep it up!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I agree.  You're getting better.  You have a couple of inclusions (holes filled with slag) in the second weld, but the improvement is obvious.  BTW, there WAS an ad that popped up this time, like Zap was talking about last time...for poker.  You might want to post the pix directly on weldingweb to avoid that and also to avoid breaking the links once the pictures are gone on the other site...keep up the practice.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Originally Posted by smithboyI agree.  You're getting better.  You have a couple of inclusions (holes filled with slag) in the second weld, but the improvement is obvious.  BTW, there WAS an ad that popped up this time, like Zap was talking about last time...for poker.  You might want to post the pix directly on weldingweb to avoid that and also to avoid breaking the links once the pictures are gone on the other site...keep up the practice.
Reply:My Google ToolBar blocked the pop-up - a very good program, and it's free!!!http://toolbar.google.com/T4/Sure, I can fix it... I got a welder!!!
Reply:my pop up stopper was off...because i need it for the other smileys ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I cant add to anything not aready said by zap and smithboy.keep practicing any youll be great in no time.
Reply:Originally Posted by teknitionI cant add to anything not aready said by zap and smithboy.keep practicing any youll be great in no time.
GMT+8, 2025-12-20 03:45 , Processed in 0.093911 second(s), 18 queries .
