Autocad to pdf ???
发表于 2021-9-1 00:59:39 | 显示全部楼层 |阅读模式
A while ago someone sent me a drawing that they had made on Autocad and when they sent it it had been converted into a pdf (adobe acrobat file).  Does anyone know how to do this?  Can you do it straight from autocad or do you need an actual adobe program that converts it?Thanks
Reply:nevermind  I found a little program you can download that does it
Reply:i do this all the time at work, adobe acrobat professional is the best, but there are cheaper options like broadgun or acrobat elements that work too
GMT+8, 2025-12-20 03:59 , Processed in 0.121899 second(s), 18 queries .
