I may have the chance to get a Lincoln Wire Matic 225 welder at little to no cost. I am told the wire feeder isn't working. What can that mean in terms of what needs to be fixed/replaced and how much to expect?Thanks.
Reply:Could be as simple as a blown fuse or a loose wire. Also a bad feed motor or the wirespeed control board. It should be fairly easy to troubleshoot if you can get Lincoln on the horn with you.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:the repair couldn't possibly be more than the welder is worth
