plastic welding
发表于 2021-9-1 00:59:29 | 显示全部楼层 |阅读模式
Can someone give me some info on plastic welding,I have searched the forum but couldnt find anything about.Hope you can help me out.www.weldingtechnology.150m.com
Reply:As I recall it's plastic filler rod and a hot air gun.  Never done it myself, but I recall reading about it as a repair procedure for motorcycle fairings back in the day.Kalroy"It's all about the OODA Loop."
Reply:what do ya want to kno, how to? who does ?, where to buy? its using hot air,or  a gun  like a hot glue gun, its melting the plastic then fusing it together. auto body- repair places do it. can be bought at online tool stores or in body repair supplyers.
Reply:I have a HF plastic welder. Cant do it to save my life. I just make blobs I can throw at people.Drivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:There is an article in either Home Shop Machinst or Machinist Workshop.  The author was pleased with his HF plastic welder. Main point was he used a router speed control to throttle the heat.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Originally Posted by drivesectorI have a HF plastic welder. Cant do it to save my life. I just make blobs I can throw at people.
GMT+8, 2025-12-20 03:44 , Processed in 0.201298 second(s), 18 queries .
