Lincoln V350 PRO
发表于 2021-9-1 00:59:26 | 显示全部楼层 |阅读模式
Hi Guys n GalsDoes anybody know of a type (make) of welder that can sucessfully run Lincoln NR400 2mm wire, that is not the Lincoln V350 PRO? If not, does anybody know someone who happens to have 8 no. V350 PRO's for Hire, at sensible rates???
Reply:Seeing as how it looks like you are desperate, why in the world would we give you a sensible rate???
Reply:What are you trying to weld ?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-20 04:01 , Processed in 0.070890 second(s), 18 queries .
