Miller 456P - modify?
发表于 2021-9-1 00:59:26 | 显示全部楼层 |阅读模式
We are currently using a Miller 456P to do some mig welding and would like to know if there is a way to convert this machine to stick weld.
Reply:This is the Invision, right?  You probably cannot.  But Miller would be the guys to ask, they can tell you right over the phone, 1-800-4-A-MILLER.Sometimes these big MIGs can run a decent Constant Current power supply that might be able to Stick weld, but as a general rule this one is still a Constant Voltage power source, not Constant Current.  That's the biggest difference between the wire-feeder power sources and the SMAW/GTAW power sources.I do note that said machine IS rated for Carbon Arc Gouging, which is commonly done with CC and CV machines.
GMT+8, 2025-12-20 04:00 , Processed in 0.094982 second(s), 18 queries .
