Looking to some s/s bend
发表于 2021-9-1 00:59:25 | 显示全部楼层 |阅读模式
Hi i'm looking in s/s bend long and short radius. Is someone have a web site were they sell bend ??I will built myself a header and 304 will be enough for that Thank a lot
Reply:looking in the latest edition of "National Dragster"...Hmmmlook at what i found...there you go!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Burns Stainless should have everything you need including technical help as well.Burnsstainless.com- Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:thanks a lot burns stainless is very good, but i'm looking most for a place who just sells bend not "racing bend" with high price of "racing item" ... thank a lot
Reply:SPD is pretty reasonably priced.  Also, you can go to ebay and look for a seller named UBendman.  He sells a lot that's not listed on ebay, and at cheap prices.  When you buy a $100k mandrel bender, you wind up owned by it...and have to practically run it nonstop to make it pay for itself.  Therefore, prices are getting competitive in that market.Also, you're going to be best to buy the 180 degree bends and cut them to whatever you need.
Reply:What diameter tubing are you looking for?  I might know of a fabrication shop that does some "tubular fabrication" including mandrel bending...
GMT+8, 2025-12-20 04:34 , Processed in 0.089058 second(s), 18 queries .
