Looking for a welder to weld an Aluminum Gas Tank in North Austin, TX area
发表于 2021-9-1 00:59:15 | 显示全部楼层 |阅读模式
I am looking for a welder that can weld an aluminum gas tank around 250 gallons for my motorhome.  The tank will carry Biodiesel so it does not need to be DOT certified since it does not carry toxic fuel.  If you are in the area send me your email address and I will send you the design.  It will be a basic box tank with 2 baffles inside and welded to the frame of the motorhome.  [email protected].
Reply:If you don't find a welder in Texas, let us know. There are several on this forum that can produce the item you want, including myself. Again, if nobody local can do it, just supply the basic dimensions and it can be done. You wouldn't be able to weld and aluminum tank to a steel chassis. It would need brackets of some sort.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:thats  gona  be one big-long tankhow about 3-4 smaller tanks, or 2  piped together a 100gal tank is on the average, 12"x30"x48" or the one i have in back of my work truck250 is alot. why not plastic ready made  look in HF book  plus the cost of material,time and dependablityhope you find what you need
Reply:I know of a guy in North Austin or rather just north I believe. Not sure if he would do it, but he does lots of alu work. I'll PM you his email addy.
GMT+8, 2025-12-20 04:30 , Processed in 0.101962 second(s), 18 queries .
