stainless steel help.........
发表于 2021-9-1 00:59:15 | 显示全部楼层 |阅读模式
hi, i am doing a retrofit boat rail out of ss.what is the chemical used on the weld to get that polished finish? need to not see the weld bead. right now it is brownish. thank.  help
Reply:Pickling paste, Formula 302 for example?
Reply:i use a formax rouge (green then go to white) on a cotton buff wheel on my buffer/grinder to polish SS props and alum. partsbut im sure you can adapt a buff wheel to a hand grindersome use a polishing compound for autos on a  buffera fine ss wire brush(on hand grinder) will buff up but leave a satin finish
Reply:This may be a helpful source for SS cleaning.http://www.avestafinishing.comhttp://www.derustit.com/Last edited by pulser; 10-19-2006 at 01:25 PM.
Reply:if there is a grain in the metal we use a scotch pad and baby oil also i did some work on handrails for a mates boat we ran water through the rails to stop them bending
Reply:Originally Posted by jimbo666hi, i am doing a retrofit boat rail out of ss.what is the chemical used on the weld to get that polished finish? need to not see the weld bead. right now it is brownish. thank.  help
GMT+8, 2025-12-20 04:33 , Processed in 0.103465 second(s), 18 queries .
