i have a old ac arc welder, i am working on an old beet-up truck trying to weld the tranfer case back in. i was using both 6011 and 6013 rod both 3/32 nether rod is working well for me mind u i am welding upside down should i go to 1/8 rod ? or less heat ? i was running the heat an about 40 amps with the 3/32 rod. i am not getting the job done please help.
Reply:The rods you're using should be fine. Are you getting burn through? 40 should be low enough you shouldn't burn through very easily. What's you're polarity?DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:When you say welding a transfer case back in, you are just talking about a steel cross member or bracket right ? You are not welding on a cast iron or cast aluminum case ? |
