garz55
发表于 2021-9-1 00:59:07 | 显示全部楼层 |阅读模式
HI, IM GARZ55,I HAVE PURCHASED AN OLD FORNEY WELDER . ITS RED AND HAS HI/LO GROUNDING PORTS THE PLUGINS FOR THE HOT SIDE ARE HORIZONTAL. i AM WONDERING WHAT IS A GOOD ROD TO LEARN ON AS I HAVE ONLY WELDED A COUPLE OF TIMES.
Reply:I would say 6013Drivesector Hobart Handler 140Hobart Handler 180Ready Welder 2Hobart Air Force 400Airco Stinger 225Of all the things I've lost, I miss my mind the most."OZZY"
Reply:6013 and 7014.  Start with flat position welding.see link for more info on various SMAW electrodes.http://www.esabna.com/EUWeb/FM_handbook/577fm1_1.htm
Reply:what he said...and stop yelling!! ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Whats The Best Way To Determine The Heat Range? By Thickness Or Start Low And Work Up Till It Flows Right? My Friend Showed Me On His Welder But He's Not Here To Show Me So I'm Stumbling Around In The Dark.
Reply:i WILL CHECK THE LINK.THANK YOU FOR NOW. MUST EXIT FOR THE RAIN LOCKER AND THEN SLEEP 4AM COMES QUICK. WILL RETURN AT LATER DATE.
Reply:Originally Posted by garz55i WILL CHECK THE LINK.THANK YOU FOR NOW. MUST EXIT FOR THE RAIN LOCKER AND THEN SLEEP 4AM COMES QUICK. WILL RETURN AT LATER DATE.
GMT+8, 2025-12-20 04:31 , Processed in 0.098101 second(s), 18 queries .
