mig 4140 to mild steel?
发表于 2021-9-1 00:59:01 | 显示全部楼层 |阅读模式
If i mig 4140 to mild steel, will I maintain at least the mild steel strength?  I am planning on pre heating the 4140.I am welding 1x2 x .083 rectangle mild steel to 2 3/4 x .300 4140 tubeThank youSean
Reply:Do you mean 4130??? Or 4340?? Chromo, correct?? Yes, it welds together well, use regular er70-s2 rod, or mig wire, and have at it. You will retain good strength.
GMT+8, 2025-12-20 06:01 , Processed in 0.099592 second(s), 18 queries .
