Aluminum water tank
发表于 2021-9-1 00:58:57 | 显示全部楼层 |阅读模式
Would aluminum be a bad choice for a water tank? I'm thinking of building a 100 gallon tank but not sure if there would be a problem with corrosion.Campbell Hausfeld Fluxcore 80Thermal Arc 185Millermatic 250JD Squared model 32 bender
Reply:i made a quench out of 10Ga aluminum works just fineChuckASME Pressure Vessel welder
GMT+8, 2025-12-20 04:31 , Processed in 0.094584 second(s), 18 queries .
