.065 304 stainless pipe
发表于 2021-9-1 00:58:54 | 显示全部楼层 |阅读模式
when tiging this pipe is it a good practice to purge the pipe,and what gas would be used.thanks,i
Reply:Originally Posted by troubleshooterwhen tiging this pipe is it a good practice to purge the pipe,and what gas would be used.thanks,i
Reply:Nitrogen works well to, and is a lot cheaper.I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:You guys...Last edited by Clanweld; 11-26-2006 at 07:54 AM.If you don't have the time to do it right, then you definitely don't have the time to do it over.
Reply:Originally Posted by ClanweldYou guys...
Reply:Just a flood of knowledge is all...fun to read!If you don't have the time to do it right, then you definitely don't have the time to do it over.
GMT+8, 2025-12-20 05:08 , Processed in 0.097931 second(s), 18 queries .
