Problem with Miller Bobcat 225
发表于 2021-9-1 00:58:49 | 显示全部楼层 |阅读模式
Our welder/generator on our service truck is acting up.  It will strike an arc, then after about 1/2 inch if welding, it quits, but the engine is still running fine.We have had this unit in service for several years and use the generator several times a week, and the welder maybe once a month.Any ideas where to start to look?
Reply:Further info, I misunderstood the radio message I got.  It welds, but only at the coldest setting, no matter what the heat level is set to.
GMT+8, 2025-12-20 05:12 , Processed in 0.040309 second(s), 17 queries .
