TIG Welding Aly
发表于 2021-9-1 00:58:46 | 显示全部楼层 |阅读模式
Hi guys I'm trying to weld 5 mm  5356 Aly plate it's a small hole in the bottom of a boat 1 3/4" X 3"  near flat section,The rod argon flow and current are correct. and good looking weld But as the weld cools i get a rootline crack.I  have worked from the ideal settings to either extreme, to no avail can any one help please ?
Reply:Sounds like it isn't clean or you haven't ground out the crack/hole farther than it was originally created.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:what would help is to let us know the machine your using?and a pic would be nice also.as i repair alum boats all the time. TELL US MORE
Reply:I agree, a picture is worth 1,000 words !   John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneI agree, a picture is worth 1,000 words !
GMT+8, 2025-12-20 05:10 , Processed in 0.138919 second(s), 18 queries .
