Miller VS Hobart
发表于 2021-9-1 00:58:46 | 显示全部楼层 |阅读模式
Is the Hobart 210 as good as the MM210?  This is not for production but for use around the Barn.And will the Miller 250 Gun fit the Hobart 210?Thanks and I'm sure I'll get different views, and thats fine with me.I do thank you.Last edited by jonesiera; 12-17-2006 at 05:29 PM.
Reply:Originally Posted by jonesieraIs the Hobart 210 as good as the MM210?  This is not for production but for use around the Barn.And will the Miller 250 Gun fit the Hobart 210?Thanks and I'm sure I'll get different views, and thats fine with me.I do thank you.
GMT+8, 2025-12-20 05:15 , Processed in 0.105840 second(s), 18 queries .
