Stainless Rods?
发表于 2021-9-1 00:58:36 | 显示全部楼层 |阅读模式
Can someone tell me where they have ordered 309L-16 or 308L-16 rods at less than 10# at a time? I can't see to find any place local that carries them in smaller quantity, all they have for stainless is a universal rod that they sell 6 rods for $22.00! Also can someone tell me if a 309L-17 rod can be used with AC?Thanks RON
Reply:I just went through this last month. I lucked out and found that one of the local welding supply places had an open box of Lincoln Red Baron 308-16L at one of their other stores (60 miles away). One of their guys who runs between the stores brought some back with him and I ended up getting 3 lbs for $30. Otherwise, they (and their local competitors) wanted me to buy an entire box (8-10 lbs depending on the manufacturer).The only other way to do it would be to find another welder who needs some and split a box.Good luck.Dave
Reply:Try McMaster Carr  http://www.mcmaster.com/ This is where I purchased mine. in 1 # container for TIG welding
Reply:Thanks guys, I'll get in touch with some other welders I know and see if we can double/triple up on some rods. Good idea. I'll check out that web site now.RON
Reply:Thanks Flmeier, went to McMaster Carr and it was just what I was looking for. The order is in!RON
GMT+8, 2025-12-20 05:33 , Processed in 0.148439 second(s), 18 queries .
