Warning Label on Tank
发表于 2021-9-1 00:58:23 | 显示全部楼层 |阅读模式
I just got a new CO2 tank that has never been filled.  I know the label says not to remove it, but is it ok to remove it so I can paint the tank? Attached Images
Reply:Odd that you would have an unpainted tank.  Is it stainless?  You could mask off the label if you are determined to paint it.  Oops!  I see it is aluminum.  I would avoid painting because you would have to acid prep the surface and you are dealing with a high pressure cylinder.
Reply:its aluminum
Reply:That label looks like a little more than your typical mattress label. About the 6th bullet down says that tanks that have been refinished need re-certified. Does painting equal re-finished. I don't know. .
Reply:Thats what I was wondering.  I'll ask the guy at Airgas i guess.
Reply:How about a nice polishingDewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:It has a nice finish on it already - I just wanted to paint it a different color - I've never seen this sticker on any other tanks though Attached ImagesLast edited by vaden; 01-26-2007 at 01:48 AM.
Reply:The tank is too pretty to paint. Catalina Cylinder powder coats their tanks, check with them. The telephone number and web address are on the tank.
Reply:Looks like a scuba tank.  And I agree, just leave it raw, Its gonna get banged, nicked, scratched, and whatever else, and if you do do something, powdercoat may be the way to go, but...  Its a tank.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:I'm with Littlefuzz - some Mother's polish and elbow grease would be cool Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:there is a chance that if you do paint it nobody will fill it.  paint will conceal cracks and other deformities, i know its a new tank and all, but you know how people are about liability...
GMT+8, 2025-12-20 06:16 , Processed in 0.066699 second(s), 18 queries .
