DIY Cooler ?
发表于 2021-9-1 00:58:18 | 显示全部楼层 |阅读模式
Would it be possible to use a fuel pump from an EFI fuel system in a DIY cooler? Most are rated at 48PSI and 4-4.5 Quarts/min. Or would a fuel pump for a carb engine work? They are rated at 9 PSI and 5-6 quarts/min. The EFI pumps can be found new for 70 plus shipping. Just curious and looking for something different. Thanks
Reply:Originally Posted by SteveMc79Would it be possible to use a fuel pump from an EFI fuel system in a DIY cooler? Most are rated at 48PSI and 4-4.5 Quarts/min. Or would a fuel pump for a carb engine work? They are rated at 9 PSI and 5-6 quarts/min. The EFI pumps can be found new for 70 plus shipping. Just curious and looking for something different. Thanks
Reply:So, does the PSI rating matter at all? Just as long as you have enough flow? I figured 1.25qt/min is about 19 GPH. Is it possible to have too much flow? Could I just use a 5 gallon bucket and have the exhaust flow back into the bucket? What would the water temp need to be below? Thanks
Reply:I read that water out of a garden hose is like 60gph.  Just giving a point of reference.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:The pump will fail.Fuel flows through the motor on an EFI pump- as a way to cool the motor and also provide lubrication.If you flow water through an EFI pump, it will fail. Water is the #1 failure of an EFI fuel pump in a car.
Reply:how about an electric water pump?
Reply:I've seen home-made cooling tanks that used a pump from an evaporative cooler sitting in the bottom of the tank. I myself have a coolant pump from a Coke machine that has a rotary vane in a housing. Most anything that will move enough water will work.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
GMT+8, 2025-12-21 07:25 , Processed in 0.092145 second(s), 18 queries .
