Clean Welding Table
发表于 2021-9-1 00:58:17 | 显示全部楼层 |阅读模式
How do you guys clean the splatter off your tables? I know for certain not to use a grinder. I saw a thread here once before and have done a search but could not find it. Thanks for your help.
Reply:Use a flap diskVarious GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Gee, I thought everyone was just using a grinder...at least that's what Ive been told to do!ThermalArc 185MillerMatic 180 w/ AutosetVictor Cutskill Oxy/AcetyleneThermal Dynamics Cutmaster 38and spite!
Reply:Flap disk work great. 80 grit will do fine without taking away metal from the surface.Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:You can use a grinder but if you do get a disc with a threaded hub and make sure you have it flat on the table . don't tilt it and it will work just fine._________________Chris
Reply:What about antisplatter spray?  I wonder how that would work, if you sprayed the table before you started.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:What is this "clean table" you are talking about??  Explain what a "clean table" looks like please. I may have one if I only knew what they look like. I'll go looky.
Reply:LOL, was wondering, but your right sandy. We should have taken a picture right after completing the table so we can remember what it looked like..Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:All I use is a 80 flapper. I run it flat and make sure I don't take any of the surface off. It has been working great.
Reply:can you scrape it off?  the only reason i would shy away from anti spatter is it smells kinda nasty when it burns.  i tack things to my table then grind the welds off all the time, why so against grinding on table.  obviously it takes some care and you have to try and avoid leaving big divots, otherwise it's no big deal.
Reply:Flap disc layed flat.  The threads on some grinders stick out to far to lay flat, but I always grind down whatever is sticking out from the hub.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:I found a big heavy chisel looking thing used for installing carpeting.    I ground an edge on it and use it to scrape the slag and stuff off the table.There are no small projects
Reply:Originally Posted by littlefuzzFlap disc layed flat.  The threads on some grinders stick out to far to lay flat, but I always grind down whatever is sticking out from the hub.
Reply:Thanks for the replies. In the past I have used a chisel or heavy scraper used for cleaning mortar off floors but have wanted something a little easier and that would not grind down the table.Thanks again.
Reply:I use my Wonderbar to chip off the "herbies" (balls) and then finish with a flapper.  If you use splatter spray don't use a flapper w/o Acetone to clean it off first.Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:Originally Posted by rusty ripplecan you scrape it off?  the only reason i would shy away from anti spatter is it smells kinda nasty when it burns.
Reply:Grinder held flat. Do it all the time at work. These tables have had spatter ground off for years. It takes alot to wear down a welding table. Dave
Reply:I dont make a mess on my table.. I give it a acetone bath and thats that  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:What did you do when you had to stick everything though?Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
GMT+8, 2025-12-20 06:16 , Processed in 0.068922 second(s), 18 queries .
