Shop set-up in basement....
发表于 2021-9-1 00:58:07 | 显示全部楼层 |阅读模式
Hi there, new to the forum. I'm thinking about setting up a small shop in my basement. It will be at one end of the basement but my furnace with hotwater heater with pilot light supplied by natural gas will be at the other end. Approx. 15 feet away. My work shop will have an exhaust fan running when I'm working. I want to know the dangers of having a tank of argon or argon mix in the basement with a pilot light running on my hotwater tank and furnace. Any comments are welcomeThankyou
Reply:I wouldn't worry about them blowing up if thats's what you mean...... acetelyne well check my other post and this news clip.http://www.wmur.com/news/11143499/detail.htmlhttp://www.weldingweb.com/vbb/showthread.php?t=9620_________________Chris
Reply:Argon is inert...it will not combust.
Reply:make shure you are well ventilated from fumes you mentioned ventlation fan make shure it can draw fresh air in as it draw fumes out
Reply:I would be more worried about catching the house on fire from a stray spark.  grinding and welding can burn ya and things around it.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-20 06:16 , Processed in 0.088425 second(s), 18 queries .
