Cost of Millermatic 175 Regulator setup?
发表于 2021-9-1 00:58:00 | 显示全部楼层 |阅读模式
I have an opportunity to purchase a Millermatic 175 that comes with a brand new mig gun (unit was only used for aluminum), but does not have the regulator gauge set up.Can anyone tell me where to find the set up and about how much it should cost?
Reply:http://cgi.ebay.com/MIG-WELDIND-ARGO...QQcmdZViewItemThat's just one example from a quick search on eBay for "argon regulator".  You can also go to online welding supply stores and just browse.  Keep in mind that if you plan on using 100% CO2 instead of an argon mix, you should get a regulator designed for it, which is a little more expensive.
GMT+8, 2025-12-20 06:15 , Processed in 0.086201 second(s), 18 queries .
