I am getting ready to attempt a job, welding cracks in a copper electrode used in a steel mill. Has anyone ever welded copper? Can you give me some advice, and/or some specs as to what kind of wire and/or electrode. Should I preheat? anything u can tell me would really help. Since I know nothing at all about welding copper. Thanks for the help
Reply:I would suggest going to www.ampcometal.com and check out the info on Copr-Trode filler metal. I think they have the largest selection of Aluminum-Bronze, Silicon-Bronze, and Copper material. They also have good tech info! Hope this helps!!----------john
Reply:I think with copper, you need all the heat you can get. I dont think preheat will help much. Do a search for copper. Either pulser or Lorenzo welded some tubing up as an experiment. He tiged it and it looked really nice. Sounds like you might be working on a huge chunk of the stuff though (I have no idea what kind of electrode the steel mill would use). Stay tuned, someone will chime in..Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last. |
