mig welding chrom molly
发表于 2021-9-1 00:57:58 | 显示全部楼层 |阅读模式
I heard that you can only tig weld chromo molly. Is this true. If so why.
Reply:You can mig it, However it is not legal with most race org. There are a few threads on this subject already.ZAP posted the NHRA rule book a couple times.What are you building?Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:You can mig weld it,tig it or stick weld unless your restricted as patriot said
Reply:Can oxy weld it too?.
Reply:I am welding A arms for a minibuggy it will not be used in any racing just family fun. Thanks for the help
Reply:You should be fine for what your doing..Just dont get it too hot..Once more for when it really matters.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Paul ( ZTFab ) has posted a few times on this as well, I think tig is the better way to go as Zap does but I believe Paul mostly mig welds all his parts and he builds off road trucks and I believesome buggies. PM Paul as he would be the guy to ask.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Originally Posted by matCan oxy weld it too?.
Reply:You can gas weld chrome moly too.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
GMT+8, 2025-12-20 06:15 , Processed in 0.093643 second(s), 18 queries .
