Differential housing repair
发表于 2021-9-1 00:57:54 | 显示全部楼层 |阅读模式
I have a front differential housing from my suburban that has one of the ears that bolt it to the frame broken off.  I have two questions about this repair:1) Is this a safe repair?2) Would it be better to TIG or just braze it back together?Thanks.
Reply:Hey BMG,IMO, you would be better to braze or even better, silver solder. The housing is a casting, and the lower heat range of brazing or Sil-Sol. would avoid cracking. I have done Sil-Sol on transmission lugs with great success that are still in service. I use a low-temp/high tensile Sil-Sol for these applications....DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:I concur with Yorkie that a braze job would be fine for the repair. I would say to use a silicon bronze rod for the repair, as the strength is greater than the sil-sol. But, the sil-sol will bond maybe the best. Just clean the hell out of it first!!
Reply:Hey,Thanks for the replies.  I think I will go with the silver solder for this application.  This makes it a lot easier.Thanks again.
GMT+8, 2025-12-20 06:40 , Processed in 0.292133 second(s), 18 queries .
