pin hole repair in aluminum
发表于 2021-9-1 00:57:53 | 显示全部楼层 |阅读模式
Need to patch small pits in aluminum plates without re welding. Is their a liquid or powder out there to patch these holes. It has to look same as aluminum for cosmetic reasons
Reply:Only thing I can recommend is Lab Metal or JB weld. I take it this will be done purely for cosmetic reason, not structural?Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:yes have already tried that Its to dark
Reply:hmmm I'm stumped then. Can you supply us with a picture of what you are working on? Welding might be your only option.Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:yes, If i can figure out this we-site
Reply:It took me an hour to find out how to post a question and still leary about it.
Reply:lol, thats ok. here is a link to hosting pictures.http://www.weldingweb.com/vbb/showthread.php?t=111Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:How thick of a metal are you working with. at school if its atleast 1/8 thick we drill the hole a little bit bigger fill if with a filler metal(With out welding it). And just put a little jb weld of the side of the rod. It works better on thicker meterial. But I've done this and polished it out to look almost perfict.
Reply:Dee,Check out a product called Alumaloy.  You can find information on it at www.aluminumrepair.com.
Reply:How about devcon or metal set. If you check the industrial supply catalogs or web sites you'll find many aluminum filled epoxy puttys. An exact color match match might be a tougher find.
Reply:Lead will work and the color would be close.it's easy to work with I don't know how much contact with pepole it would have but if it's only cosmetic,I'd try lead body filler or a lead tin solder mix.
Reply:If this is only a cosmetic repair you will find Devcon make a product in a tube called Liquid Aluminum. You can find it in many auto parts houses as well as the hardware stores such as Home Depot, Lowe's, Wal Mart,etc.etc.I think the color is pretty close to unpolished aluminum. Hope it helps
Reply:have you tried epoxy and aluminuim filings?  it may take a few tries to get the proportions of epoxy to filings right.
Reply:How bout that hts 2000 stuff?Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
GMT+8, 2025-12-20 06:40 , Processed in 0.091391 second(s), 18 queries .
