Fabrication supplies
发表于 2021-9-1 00:57:52 | 显示全部楼层 |阅读模式
I have a list of a few things that I need to find sources for:Weld in, threaded bungs for use in things like over flow tanks in cars, O2 sensors, fuel tank inlet/outlets.  Looking for them in stainless and aluminum mostlySpherical rod end and or "hiem joints" (sp?) for building suspension piecesvarious tabs to weld on for bolting on various thingsAnd any other weldon gadgets or fittings that might make fabrication a little easier.
Reply:I've been getting Heim joints (spherical rod ends) from here:http://www.racerpartswholesale.com/rodindx.htm
Reply:Here is my number one source for rod ends and other misc pieces for my suspension parts. Just don't put me out of business, LOL.www.midwestcontrol.comPatriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:www.jerrybickel.com they have threaded bungs, sst and Al, heims from Aurora Bearing (the best btw), if you call Jerry Bickel's talk to Steve Klosterhoff, he is the parts manager and knows his stuff
Reply:Cool deal, I'll check em out guys, thanks
Reply:Here -  http://www.fkrodends.com/and here-  http://www.aa-mfg.com/I get most my chassis parts from these two.
GMT+8, 2025-12-20 06:40 , Processed in 0.092643 second(s), 18 queries .
