Pop Quiz for all Experienced welders
发表于 2021-9-1 00:57:52 | 显示全部楼层 |阅读模式
1.  What is a M2 tacking test?2.  Heliarc Test?3.  What is a pedric bendign machine?4.  What is the difference between P1 and P2 piping systems?5. What is fit saddles?The first one to get it right gets an awesome gift?
Reply:2. Heliarc Test?
Reply:To start a very gracious thank you.I asume you mean it is a very easy test?
Reply:1. Have no idea2. Heliarc = tig3. should read pedrick bending machine4. P1 and P2 are just labels on a piping schematic, so depends on what they are labelling  5. has something to do with horses
Reply:what's a stick tack welding pas LH test?
Reply:OK, I have to play too . . .1.  What is a M2 tacking test?A test you have to pass both vertical and overhead to get a job in most shipyards.  If you don't even know what it is, chances are you haven't passed.2.  Heliarc Test?Must be able to weld using old terms for things.3.  What is a pedric bendign machine?A machine that bends what is put in it.  It bends bigger stuff.  Similar to the "BP-79 Exaust Pipe / Tubing Bender" (yes, that is a direct quote of actual advertisement copy).4.  What is the difference between P1 and P2 piping systems?15. What is fit saddles?Used to align and support cylindrical objects, like pipe and tubing, in shipfitting -- see question one -- if you don't know what it is . . .Sorry, best I can do . . .  The first one to get it right gets an awesome gift?[/QUOTE]Last edited by phila.renewal; 04-12-2007 at 07:21 PM.
Reply:OK, enough playin . . . if you are really interesting in shipfitting or pipefitting, you can apply for a paid apprenticeship . . .http://www.apprenticeschool.com/programs.htmlIt looks to be a pretty good deal if you are young and want to learn.  Location can't be beat.
Reply:1. What is a M2 tacking test?BMW's test on the failed 3-series model before the M32. Heliarc Test?It's a test  held on a heel-shaped boat (heely arc?)3. What is a pedric bendign machine?A typographic error4. What is the difference between P1 and P2 piping systems?P1 is installed in a short time- you only have to pee once when installingP2 takes much longer and you will have to pee twice while installing it5. What is fit saddles?Custom-made saddles for your horse....or sheep.The first one to get it right gets an awesome gift?Okay- PM me and I'll send you my address for my awesome gift.
Reply:Boy did this go downhill fast!!  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-20 06:49 , Processed in 0.098498 second(s), 18 queries .
