What welding rod do I use?
发表于 2021-9-1 00:57:48 | 显示全部楼层 |阅读模式
What welding rod do I use to weld 253 steel?
Reply:I would try a 308L or better yet a 309L, the material data property sheet says it was developed as an alternative for 310 and 446 stainless in heat resistant applications. Are you going to TIG it or Stick it? What project or job is this material going on?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-20 06:43 , Processed in 0.088421 second(s), 18 queries .
