Vertical storage - small spaces
发表于 2021-9-1 00:57:47 | 显示全部楼层 |阅读模式
It was raining, so I decided to clean up my shed (shop to you guys) the other day. I had lots of little bits in a bucket left over from projects and some longer lengths lying in a jumble on a rack.So the plan was to make something out of the little bits to store the big bits i.e. to not buy anything.The photos seem tiny, but maybe they'll be bigger when I upload them?Holding the vertical bits in the rack are some short lengths of 3mm x 16mm flat that sit in grooves cut into the 40mm x 5mm flats.Scott Attached Images
Reply:looks goodChuckASME Pressure Vessel welder
Reply:Oops. Should have put this in the projects forum. One of the Mods might move it.
GMT+8, 2025-12-20 06:43 , Processed in 0.109739 second(s), 18 queries .
