Propane/Oxy. cutting
发表于 2021-9-1 00:57:45 | 显示全部楼层 |阅读模式
I know that you should change hoses and tips for acetylene to propane conversion but what do you guys recommend for a regulator, can I use the acetylene reg. or do I need another one? What pressure should the propane run at?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:I've used the same reg that is set up for acetylene but in hind sight a person may want to check with a regular torch shop on that. It may make a difference what types of plastic and/or rubber components are in any particular regulator. Not like there is an instant decomposition or anything. It's a long term affair. Gives you time to research.
Reply:this might help:http://www.weldingmag.com/323/Issue/...se/45963/Issue
Reply:You don't need to change hoses or regulators, just tips.
GMT+8, 2025-12-20 06:45 , Processed in 0.091661 second(s), 18 queries .
