Who Makes this Welder
发表于 2021-9-1 00:57:41 | 显示全部楼层 |阅读模式
I just won the auction on this welder. I want to know who makes it and what kind of quality is this welder? I recently bought a Lincoln Pro Mig 180 which is a 220 and wanted to get a 110 welder also. Here is a paste of the welder. Thank Whitey87 AMP, 115 VOLT FLUX AND MIG WELDER.For mild steel, stainless steel, and aluminum. Weld with gas or perform flux cored gasless operations. Welding current range: 25 to 87 amps Input: single phase 115 volts, 60 Hz Open voltage: 19 to 30 Duty cycle: 20% @ 75 amps, 45% @ 50 amps Draws 21 amps @ 120 volts Weldable wires: 0.023'' to 0.035'' steel and stainless steel, 0.030'' to 0.035'' aluminum, 0.030'' flux-cored Condition: This welder is used, it has been tested and works great, includes whats shown in the picture.Part Number: 06098 Click an Image to Enlarge
Reply:No image, so it's  tough to tell. There are at least a dozen low cost 110V welders that fit the description.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Here is a pic of the welder. Thanks for the help. Here is the link for the welder. The only difference between this one and the one I won is this one is 90amp model and mine is a 87 amp model. http://cgi.ebay.com/ws/eBayISAPI.dll...4841&rd=1&rd=1
Reply:That is a Chicago Electric sold mostly by Harbor Freight. I think that eBay seller is a HF reseller or damaged goods seller. There are a few on eBay. They work for what they are. A few members here have them and use them. I'm sure you can get parts and consumables from either HF or by calling their customer service number.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:For $91 total cost, I think you did pretty well.  If it works, you are ahead of the game.  If it doesn't work, you can get parts from HF.Good luck and enjoy it.Let us know how it compares to your pro mig for what it does.
GMT+8, 2025-12-20 06:41 , Processed in 0.576349 second(s), 18 queries .
