Buying a torch
发表于 2021-9-1 00:57:38 | 显示全部楼层 |阅读模式
Where is the cheapest place to get a smith cutting torch.  Will just be used for cutting and heating.  the places in town are asking 400 for a kit but i think ive seen them somewere cheaper
Reply:someone on here was selling one a while back I'll go back and dig through the post and see if i can find you the guys name and #63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:dinnertime is the name of guy that had the torches for sale. you can pm him to check availability.  I found the thread by going to the search at the top of the page.63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:nane of post is "bunch of stuff for sale"63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Smith setups go for 200-250 on Ebay.  I paid 300 through weldingsupply.com.  This is all for the medium duty tool box outfit.
Reply:Now my next question is what are your opinions on a propane set up?  What is all different hardware wise from a/o set up
Reply:Check out this link from Wikipedia. It has some good info. http://en.wikipedia.org/wiki/Oxy-fue...ng_and_cuttingLincoln AC/DC 225/125 Stick Linde HDA-300 MillerMatic DVI MIG Miller Dynasty 200DX Hypertherm Powermax 1000
Reply:Do a search of this forum, it's been covered many times.  Basically, to run propane, you need only to buy the special cutting tips.  Smith very strongly recommends you use propane if you are only going to be cutting or brazing.  They will answer any questions you have.  In advance, no you don't need to change the hoses or regulators to run propane.  Your hose will deteriorate a little more quickly, though.  You may get 3-5 years instead of the standard 5-7.  When the hose does eventually break down, replace it with the T grade hose.
GMT+8, 2025-12-20 06:43 , Processed in 0.105542 second(s), 18 queries .
