Guys I am getting ready to change out my wire. I have cut the line behind where it feeds in and removed the spool. Now, how do I get the wire from the maching and out of my line and gun to put the new wire spool on and rethread to run? ThanksWhitey
Reply:Maybe I'm the only one. I cut the wire past the contact tip, screw off the contact tip (over the now clean end of wire) and then pull the spool off the resistor and wind up the wire, making sure not to let it get away when it comes back through the drive rolls. 10 feet of wire is 10 feet of wire.
Reply:Originally Posted by MAC702Maybe I'm the only one. I cut the wire past the contact tip, screw off the contact tip (over the now clean end of wire) and then pull the spool off the resistor and wind up the wire, making sure not to let it get away when it comes back through the drive rolls. 10 feet of wire is 10 feet of wire.
Reply:Loosen the drive tension, cut off the burnt ball and wind it back onto the spool then remove the spool, unless you need some new banjo string ...BobBob WrightSalem, Ohio Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Originally Posted by weldrwomn...At the end of the spool, if all you have is that 10 feet of wire, it won't do you a bit of good to save it ....
Reply:[QUOTE=weldrwomn]10 feet of wire may be well and good when you are somewhere else in the spool besides the end. At the end of the spool, if all you have is that 10 feet of wire, it won't do you a bit of good to save it (for welding anyways)I always save the wire for TIG welding, unless of course, it's flux core!-----john |
