colors
发表于 2021-9-1 00:57:28 | 显示全部楼层 |阅读模式
what to the colors represent - is each a bead? - thanks, ed Attached Images
Reply:affirmative
Reply:Hmm, are these your test questions?   http://www.weldingweb.com/vbb/showthread...285#post102285Last edited by MAC702; 05-31-2007 at 03:31 PM.
Reply:Each color is run at a different amperage or direction.The blue root and fill passes must be run at 56.7658 amps per millimeter of rod thickness (30.456 if counting the flux); downhand.The red hot and cap passes are at 68.382 and 57.349 amps, respectively; uphand.The green fill pass one must be run while upside down and blindfolded or you fail.That was fun.
Reply:Mac - no test - fairly new car hobby - bought a cheapie welder (HFT 151 (220v. 150amp) - haven't tried it yet due to work demands (of the non-mechanical kind) - and literally am just trying to learn a bit before I fire the thing up - thanks! edp.s. is your last post real or just razzing?
Reply:MAC702Has the AWS changed or is that Nevada specific?I recall 42.333A/mm for root and 4th bead (fill), and flux measurement wasn't included, just wire size. i.e. a 1/8" or 3.17mm electrode is run at 134A downhand.
Reply:That's only on second Thursdays in months that start with J.Latest Toys Miller 180 Mig and Elite Mask!!Wright Welder 225ACShop OutFitters 20/20 Bending SystemHypertherm 380 Plasma30 Years of Sparking (Electrical & Welding)
Reply:Four types of passes:-1.Root Pass2.Hot pass3.Fill Pass4.Cover PassEither that, or colors just look extra special!Last edited by tanglediver; 06-02-2007 at 10:11 PM.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:What is the purpose of the hot pass?  Why is it different than a regular fill?
Reply:For SMAW(stick welding) of pipe, the hot pass is used to quickly burn out small amounts of slag trapped along the edge of the root pass. This is slag that can not be removed easily by chipping or wire brushing. The hot pass can also be used to reshape the root pass by using high current settings and a faster than normal travel speed.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-20 06:43 , Processed in 0.140613 second(s), 18 queries .
