do i need to use special wire to weld alluminized steel? or can i used regular mig wire?
Reply:Regular is fine. You'll shoot right through it and weld the steel. The weld will no longer be aluminized, of course, if you are counting on that for corrosion protection.
Reply:Originally Posted by MAC702Regular is fine. You'll shoot right through it and weld the steel. The weld will no longer be aluminized, of course, if you are counting on that for corrosion protection. |
