Floor Pans
发表于 2021-9-1 00:57:25 | 显示全部楼层 |阅读模式
Hello everyone, quick question. Ive got to replace some rusty floor pans on a camaro this weekend, and was wondering if anyone has experience with these. I really just need to know if I should cut the old pan to exact dimensions of the new pan, and butt weld it, or should I leave a bit of a lip all the way around, and lap weld it. Ive seen it done both ways, but I would like to know which way is the right way.I will be using a handler 140 with 25/75 mix, and .023 wire.ThanksMiller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:this question was asked not that long ago  go to the search and paste in    Floorboard patches... ideas & techniques?63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Beedy beedy beedy...There is no right or wrong.  The lap weld will be much, much easier.  If this is going under carpet or something, I'd lap weld it.
GMT+8, 2025-12-20 07:34 , Processed in 0.097158 second(s), 18 queries .
